Air fuel ratio guage
Discussion in 'ECU's, Electronics, and Tuning' started by hatchproject, Dec 24, 2002.
  1. hatchproject
    hatchproject Member
    I was wondering for the o2 sensor wire in the guage which wire do you hook it up with in the ecu. I heard its the white one, but not really sure. can some one help?
  2. Havok
    Havok Senior Member
    Florida
    What year, model car?
  3. hatchproject
    hatchproject Member
    it's a 92 civic hatch si with a d16z6 motor
  4. hatchproject
    hatchproject Member
  5. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    there should be 3 wires coming off the a/f gauge.. the purple one goes to pin d14 which is a white wire near the ECU.
  6. hatchproject
    hatchproject Member
    okay, thanks wasn't sure about it and didn't wna't to hook it up the wrong way. Should i cut this wirre or splice it. Some people said that you shouldn't cut the wire and just splice it is this true?
  7. pills_PMD
    New Albany, OH
    just splice into it. there are special plastic "splicers" (for lack of a better name) that will do this for you that you can get from home depot or radio shack
