Air/fuel Ratio
Discussion in 'General Tech and Maintenance' started by liquid00meth, Feb 25, 2003.
  1. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    I have been reading some things, and it was my understanding that the optimal air/fuel ratio was always 10:1. But it seems that this isn't correct at all, especially for forced induction. Comments? Wisdom?
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    generally it seems that 13:1 at WOT gives the most power. i got taht from hondata
  3. phunky.buddha
    Dallas / Fort Worth, TX
    Get on the dyno, figure out which ratio gives you the most power over a range of revs, then tune to match- once you have that, you can start playing with varying ratios to get the power where you want it at each rev band. My B20/VTEC made its best power around 11.5:1. Every setup is different.
  4. chet
    chet Senior Member
    st petersburg, florida
    yes, put your car on a dyno.
    12:1 vs 13:1 is usually where the most power is made...but as calesta said every setup is different...with turbo setups usually running richer to make the most power.
