Air/Fuel
Discussion in 'ECU's, Electronics, and Tuning' started by darwins_vtech, Mar 19, 2004.
  1. darwins_vtech
    darwins_vtech Senior Member
    Wisconsin
    hey, i am hooking up my airfuel gauge, and I was wondering, which wire on the ECU do I have to splice into. Thanks a lot.
    Darin
  2. pissedoffsol
    you want to tap it into the o2 sensor wires.
    what ecu? what car? what wire harness?
  3. Smonkeyboy
    Smonkeyboy Senior Member
    Spokane, WA
    i ran an acessory wire out to about 6in off the O2sensor in my engine bay, BUT it made me throw a code, and i still cant figure out why.
  4. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i've noticed that the same gauge will give you "faster" readings if hooked up to the o2 sensor in the engine bay as compared to the wire that runs to the ecu...
    this makes absolutely no sense at all to me, but its tried and true...
    friends accord had it hooked to ecu incoming o2 wire and it was slow as hell, but then straight to o2 and it responded right as your throttle position changed... very odd...
    but you can do it either way, check the pin out for your ecu and just hook it up to the incoming o2 wire... or straight to the o2 in the engine bay for better results...
    EDIT: and your name would imply that you LOVE cheap phones or what? vtech?
    AND: auto zone.com has a repair section WITH wire diagrams that have ecu pinouts so if you know what ecu you have then you should be all set with that site and the information it has... check repair and then manuals
  5. Tim@Canspeed.com
    Tim@Canspeed.com Member
    Wherever you take the signal from (sensor or ECU) remember do not solder the connection. Especially if you take it at the sensor. The solder can interfere with the signal.
