Air Intake
Discussion in 'General Tech and Maintenance' started by 89LudeSi, Mar 11, 2003.
  1. 89LudeSi
    89LudeSi Junior Member
    What air intakes would work properly with my 89 Lude Si? Is it possible to make any intake work onto my car? Like an intake that would fit onto a 92-96 Prelude. Because i noticed that most shops don't have intakes for my 89 Lude Si.
  2. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    You can usaully get similar intakes to fit,you need to make sure the TB diameter is similar and that it has different sections that can be manipulated to fit your applications fitment in your car.
  3. 89LudeSi
  4. 89LudeSi
  5. xj0hnx
    C.C.TX.
    Avoid the overpriced weapon R garbage.You will get the same from the one that cost a hundred dollars less.
  6. MaaseyRacer
    MaaseyRacer Senior Member
    San Francisco, Ca.
  7. vtecsir1
    vtecsir1 Senior Member
    Orlando, FL
    build one! 40 bucks will build you a simple intake. buy some bendable exhaust pipe from your auto store then a filter then the rubber coupling thingy.
  8. chet
    chet Senior Member
    st petersburg, florida
    i have a type R intake tube and K&N filter i'll sell for 50+ shipping.
    its nearly brand new, and should work very well with your setup.
    i now have an iceman...here is a picture.
  9. vtecsir1
    Orlando, FL
    that one is nicer than mine:( cost more.
  10. 89LudeSi
    Im not sure if this project will work on my car.
  11. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    chet, i saw in your pictures you got rid of your intake, I liked that custom box thing though, looked good.
    I would build by own intake.
