Aircon In An Eg Swap
Discussion in 'HYBRID -> EG-EK / DC' started by simonc, Mar 10, 2003.
  1. simonc
    simonc Member
    Just put a B16a into an EG Civic hatch. The car had air con originally and we want to keep it. I've changed the air con pump to one from a B16a, but does anyone know if there are any other parts which connect to the actual engine? Reason I ask is because on the bulkhead there seems to be a green plug which isn't connected to anything.
  2. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    my friend Helms probably knows the answer
  3. pissedoffsol
    you need a del sol vtec a/c compressor mounting bracket
  4. simonc
    simonc Member
    I'd be grateful if you could ask your friend Helmes :D
  5. pissedoffsol
  6. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    i may have a del sol VTEC bracket lying around.. PM me if you need one
  7. simonc
    simonc Member
    Basically, I have noticed that there is a metal pipe from the air con which goes to the bulkhead of the car behind the intake manifold. On this pipe is a green plug which, on our car, isn't connected. Will try to post a photo if poss.
    Just want to know if any one else has this, or can tell me what should be connected here.
  8. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    :( Sorry my car didn't even come with AC/PS.
