Compression seams good
....but everything leaks.
I just got all the fittings and crap needed to regulate my fuel system...so it will be installed tommorrow.
Got a 0-15 VDO fuel pressure guage, some 1-6 psi regulator, a napa fuel pump good to 6 psi.....and a ton of various fittings....
I've had to do the rear suspention on my Z, the rear support bracket fab on another Z, and now the Jeep is giving me problems.....so I was a little distracted from the AE86.
but from what I see, and some-one who looked at the set-up...it was dumping in to much fuel. after talking to many people on the phone...they all said the same thing...4.5 psi is to much for the set-up I have....so I was basically just shooting fuel into the engine when it ran...and it was running toooooooooooooooo rich. So if this doesn't do the trick tommorrow, then the project will be on hold for a while....
I am so tempted to just post it for sale....but nobody is going to buy a car that doesnt run for the price that I would want. So I got to get it running right first...then it's for sale...unless I ccan drift it like the monster that I wanted to build.
I have a drift clinic that I registered for on the 1st of september...so I have less then a 1/2 a week to get something driftable...and a full set of tires to drift on. I realy want to get the AE86 down there and start ripping threads off tires, but the cam shaft seals were leaking to much, and it looks like the rear main seal is leaking a lot, so I would have to pull the trany/clutch/flywhell in put in a new seal. Then tha head gasket is also pissing oil everywhere...so that means I will have to just break in to the wallet and get a new one, and possibly take the head to get shaved...so now time and money are the real things holding me back.....and energy....now that I turn wrenches again at work, and then get home to turn wrenches...I'm going to burn out before I can even drift. My other option is to get the Z built up in a week. I have the parts for the full build up, and a possible space to do the work.....but the energy thing is killing me, also with knee's shot, and a sore back....everything is going so damn slow. My 260Z finally got the rear shocks and springs installed, but all the bushings are shot to hell...but I have a full set of new bushing here right now...they just need to be installed. The fuel injected/big bore/cam/engine swap should only take a week-end to do...but I told my boss that I would work sat/sunday this week to get all the overtime I can.....if the Z gets built up...it's free.....to build up the AE86 and to trust the engine for a day of hard driveing on a block with less than 10 miles...is a risk, and money is needed to finish the build.....
So I'm at an impass.....get the AE8 done before the drift clinic, or build the Z up for the drift clinic....or cancel my spot on the drift clinic and get some money back and lose the valuable seat time...that I really need...before the big North VS. South Drift event in Oct.......That I plan on making an awesome awesome car combo for.......the Z and the AE86....both cars will be there, and in drifting shape to kick some ass...and to put some SR powered cars down the tubes....hehehe
