Alignment Results
asmallsol
Super Moderator
Finally got my car aligned today. It perfect now. here is the basic print out. I know what caster camber and toe is but SAI and Included angle I am lost on. Can someone tell me if these specs are ok also.
FL
-1.2 camber (i know what that means but what are the called for specs)
1.1 caster (" """""""""""""")
.01 TOE ("")
12.1 SAI (WTF does this mean)
10.9 Included angle (WTF does this mean
FR
-1.3 camber
.8 caster
-.01 Toe
11.7 SAI
10.4 Included angle
Front
Cross camber .1 (what does the cross mean)
Cross caster .3
Cross SAI .4
Total toe .01
Rear
RL
camber -1.5
toe .05
RR
Camber -1.2
Toe .06
Rear
Cross camber -.2
Total toe .11
Thrust angle .00 (???)
Originally posted by pills_PMD@May 14 2003, 11:52 PM
your camber are all within specs.
they go to -1.5 if i remember correctly for OEM specs
yep. that be right B) in my case, the factory called for front: anywhere between 0 to -1.5, rear: anywhere between +1 to -1.5
Cool. Also, what does the SAI and Included angle mean?
Plus I ended up buying the lifetime alignment plan so they are going to be seeing me alot in the future. For a sure in a month because 2 area shops say that they are going to be getting Corner ballancing scales :)
130 Good at any firestone store. It was a little price but it is about the same as three alignments. So for sure I will use 1 more within the next two months. Plus with autoX, better the car is aligned better the car handles.
