Alignment Results
Discussion in 'HYBRID -> EG-EK / DC' started by pills_PMD, Mar 27, 2003.
  1. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    everything was ok except the driver side front..
    -2.6* camber !!! ahhhhh ; toe 0.05*
    everything else was within tolerance, or .1* outside of it..
    front right: -1.4* camber; toe .03*
    back left: -1.5* camber ; toe .11*
    back right: -1.7* camber ; toe .15*
    so to all you who say you need a camber kit!! wrong-0~
    the driver side front can be fixed by raising my car up a little bit. that coilover is down further than the others.
    if anyone wants a picture of the printout i'll post it up
    later
  2. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
  3. CRX-YEM
    Wallingford, CT
    well how much lower than stock is your car now ??
  4. pills_PMD
    New Albany, OH
    about 2 inches lower.
    my one kuhmo is kinda fucked from the -2.6* but oh well
  5. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    you might not need a kit for a Sol, but for Chris's gen Accord and my gen Integra you need one. I should have taken pics of my Nitto's before I replaced them. They were very worn on the inside. Again not caused by toe because I have my car aligned every 3000 miles (lifetime alignment rocks!).
  6. dohcvtec_accord
    The left lane
    :werd:
  7. biglee414
    biglee414 Senior Member
    ok, the pic that dohcvtec_accord looks exactly like what my tires looked like when i took them off for the winter(before i was lowered) i just had the rims on. do i just need an alignment?
  8. dohcvtec_accord
    The left lane
    Ummm yeah. :) If you're not lowered, you've probably got some normal camber and you're probably toed to hell, which is worse for tires than camber.
  9. biglee414
