Alignmenting
Discussion in 'Wheels / Suspension / Tires / Brakes' started by GlassHeadlights, Mar 23, 2010.
  1. GlassHeadlights
    Calgary, AB
    I'm new to front end alignments.
    My dad and I started to align the toe on my CRX but didn't get close enough.
    We rotated the outer tie rods and heald the inner tie rods in place. We didn't want to start spinning them because we don't have a clue of what could happen.
    We got it close but not close enough, can we spin the inner tie rods to dial it in?
    I know all of you are going to say "take it to a shop".
  2. double0Si
    double0Si ლ(ಠ益ಠლ) VIP
    Columbus, Ohio
  3. GlassHeadlights
    Calgary, AB
  4. 95b16coupe
    95b16coupe New Member
    ct
    exactly. take it to a shop. this is one think worth getting right. and it's not that expensive.
    (i know it's not the answer you wanted, but it's my .02)
  5. GlassHeadlights
    Calgary, AB
    Makes sence...I want to drive it soon too lol.
  6. Jared759
    Jared759 Well-Known Member VIP
    SC
    Shouldn't take more than 20 minutes if the shop isn't busy. I can do mine on the rack in about 15.
  7. GlassHeadlights
    Calgary, AB
    Good. I'll take it to my shop where I work and get them to do it. My boss wants to seey car anyway, he has a super low mileage minty '89 Prelude Si.
  8. BlackFrog
    BlackFrog Neighborhood Lush
    North Freakin' Idaho
    Turning the inner tie rods will not hurt anything. They are a ball-in-socket design that is intended to rotate. Assuming ofcourse that you arent unscrewing the tie rod from the rack. Spinning the inner will also not affect your toe adjustment at all.
    And like everyone else said, align it on a rack with an alignment machine. Youll never get it right any other way
  9. GlassHeadlights
    Calgary, AB
  10. blk91b18
    blk91b18 New Member
    midwest ryda
    when performing an alignment make sure that the rear tires are as close to straight as possible. they determine how straight your car drives. and rotating the inner tie rod end is how your supposed to adjust the front toe. removing the outer tie rod end is not necessary and causes premature wear on it.
    1 person likes this.
  11. GlassHeadlights
    Calgary, AB
    Well its getting done on a rack this week....but thanks!
  12. blk91b18
    blk91b18 New Member
    midwest ryda
    good to hear. tires aint cheap
  13. GlassHeadlights
    Calgary, AB
    Mine were on sale for $55 each. :)
  14. blk91b18
    blk91b18 New Member
    midwest ryda
    word. what are they?
  15. GlassHeadlights
    Calgary, AB
  16. blk91b18
    blk91b18 New Member
    midwest ryda
    nice. i got the kumho ast. that reminds me, got to get the snow tires off.
  17. GlassHeadlights
    Calgary, AB
    Cool...
    Well it got aligned today and what a difference! I bought the car last summer, parked it, lowered it, it drove like crap so I never knew how it should be then got it aligned. No more slack, no more leaning to the right and no more fighting against the wheel. I'm stoked! Handling is much better now too, lol.
  18. blk91b18
    blk91b18 New Member
    midwest ryda
    cool enjoy it. that alingment should last about 30k miles. l8r
  19. BlackFrog
    Sorry, should have clarified, i thought he was saying rotating the tie rod back and forth when the jam nut was still tight. I meant that just rotating the assembly back and forth wont change your alignment angles... yes, once the jam nut is loose, turning the inner is what changes the toe angle.
  20. 90rs
    90rs New Member
    hey a quick Q? i find myself going thru two front tires fast my tires r gettin worn out quick anyone i need help i have a 90 integra rs..
