All half shafts are not created equal!
Discussion in 'General Tech and Maintenance' started by Ethan, Jun 7, 2011.
  1. Ethan
    Ethan Well-Known Member
    Ok im putting together my B18a1 and B16 cable transmission.
    heres what i have after a ton more of google time.
    I need any B16 half shaft.. The difference is.
    Hydro B16 = Male half shaft.
    Cable B16 = Female half shaft.
    Im also seeing a lot of people saying to use the 94-97 Integra LS
    or GSR half shaft but i havent seen any proof of this working.
    With a B18a1 Engine and Cable B16 Transmission a 90-93 Integra LS half shaft WILL NOT fit.
  2. Ethan
    Does anyone have a clue on which half shaft i can use? i dont wanna start buying em off ebay for 100-150 bucks a pop to not fit :(
  3. B16RacerN2NR
    B16RacerN2NR Working Hard VIP
    Moving back West...
    The 90-93 Integra one is the one you want...
    You sure you're not using an automatic 90-93 teg halfshaft? Is your b18a1 from an automatic teg?
    I got an auto B16 once and I had to actually grind off some of the block for the half shaft to bolt up properly.
  4. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    Have you tried to use 90-93 half shaft? I know when I did a swap for a friend; B18A1 into a 92-95 Civic with 94-00 LS transmission; the 90-93 shaft didn't work(it was slightly too high); and swapping in a 94-00 LS/GS halfshaft fit in like a glove.
  5. Ethan
    B18a1
    1st gen B16 cable trans
    91 integra manual half shaft
  6. K2e2vin
    Raleigh, NC
    What exactly didn't work? According to the Acura parts catalogs, the 90-93 Integras all use the same half-shafts including the 92-93 B17 GSRs.
