all most complete ls swap
Discussion in 'HYBRID -> ED-EF / DA' started by erebunicrx, Apr 18, 2004.
  1. erebunicrx
    erebunicrx my name is Dale
    Bristol ct
    im finishing buying all the stuff fo a 91 ls swap in to my 91 crx si. if i got this right (wich i never do), all i need is the mount kit, shift linkage, and 90-93 axles. is there any thing else? will i need to do any wireing mods (still obd0)? also what exhaust mods do i need to do? thanks in advance guys!! :worthy:
  2. brian11to1
    brian11to1 Senior Member
    Wiring: For Si, EX, and HF (port injection) models modify the engine harness to fit. DX, LX, and Standard (dual point injection) models the wiring needs to be modified for port injection. Custom wiring harnesses are available for dual point injection applications from Hasport.
    Upper Radiator Hose: 92 GSR, trim to fit
    Lower Radiator Hose: 90 Integra, trim to fit
    Throttle Cable: 90 Integra
    Clutch Cable: Stock
    Air Conditioning: Use Hasport AC bracket with stock AC compressor.
    Chassis Prep: Make a dent on the left-hand frame rail for alternator pully clearance
  3. erebunicrx
    Bristol ct
    could i use the si ecu. and do i need the teg axles?
  4. Bl6CRX
    Bl6CRX Senior Member
    UCLA
    90-93 teg axles, si ecu will work, but might not be the best for the setup
