all motor b18b?
Discussion in 'Integra' started by soto2635, Apr 15, 2008.
  1. soto2635
    soto2635 New Member
    is it worth to spend the money all im not looking for anything crazy just something with a little kick to it. i found this write up on a all motor monster. and i liked what i read it also fits my need b/cmy teg is my dd mosot of the time. anyway i want peoples input thanks!!
  2. BrutalB83
    Rochester Hills, MI
    It depends on your wants and your budget really. How much money do you have to spend and how much power do you want to make?
  3. soto2635
    soto2635 New Member
    got about 2g's amd wanting to make about 170-180 to the wheels
  4. BrutalB83
    Rochester Hills, MI
    If that's the case then the build that you mentioned would probably work out pretty good for you. I'm assuming you're talking about the "all motor LS monster" article in the FAQ section?
  5. soto2635
    soto2635 New Member
    yea, and maybe later on a 50 shot, i would really like to got forced induction but that just to much to maintain. with diffrent rods and a vfac i could make some more power? b/c on the write up it says they used the oem ls rods and no engine management
  6. soto2635
    soto2635 New Member
    what do u think?
  7. BrutalB83
    Rochester Hills, MI
    Yeah, you could definitely make more power with a good tune. I would recommend getting an ECU chipped and then custom-tuned on a dyno rather than using an AFC though...
  8. soto2635
    soto2635 New Member
    who would i go about a custom tune? what that consist of?
  9. BrutalB83
    Rochester Hills, MI
    It would consist of buying an ECU with a programmable chip and having the car tuned on a dyno by a professional tuner. I'm sure that sounds really expensive, but honestly it probably won't run you much more than the cost of an AFC (if you're buying one new) and it will be a much better and more complete tuning solution than a piggyback ever will...
  10. soto2635
    soto2635 New Member
    so for example hondata? what are ur views on pulleys as well?
  11. BrutalB83
    Rochester Hills, MI
    I'd probably skip Hondata, and just go with one of the free tuning programs like Crome. Just call up some of your local import tuning shops and see what they recommend.
    As for the pulley, I don't really have much experience with them honestly...maybe somebody else can chip in?
  12. soto2635
    soto2635 New Member
  13. get_nick
    Washington State
    pulleys are a waste of money. spend it on tuning or quality parts rather than ebay stuff.
  14. EkSivik_99
    EkSivik_99 Yea Ho FO SHo
    Newton, Ks
    check into an ls-vtec u already got the block new rods pistons buy a b16 head should be around your buget
  15. soto2635
    soto2635 New Member
    i looked into that it doesnt tickle my pickle,
  16. 90DATeggy
    90DATeggy The Pussi Snatcher
    FL
    get a small turbo u can boost 6-7psi daily i do no much maitnace i just do oil changes and check my oil it helps if u have a oil catch can installed as well
  17. BrutalB83
    Rochester Hills, MI
    Discussing PSI numbers is somewhat irrelevant until you decide what kind of turbo you want to use. A person could do higher PSI on a small turbo or lower PSI on a bigger turbo and have similar results...
  18. tutoneintegra
    tutoneintegra new to the game
    P.A. Trill
    Hey new to the site and planning a head job done on a b18b1 block *bad valve seals are the cause for it* , but I hear ls-vtec is the way to go. Which head should I use if I go v-tec and how much should I be looking to spend for one (including computer/harness) I looked on E-bay and it didn't help at all. I'm not sure if I'm going to go ls-vtec or stay with the original head.
    What do ya'll think?
  19. soto2635
    soto2635 New Member
    b16 head
  20. BrutalB83
    Rochester Hills, MI
    We all think you should start your own thread...
