All This Reference Material, And No Cel Code Chart
Discussion in 'Members' Lounge' started by Slo86GT, Jun 13, 2003.
  1. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    Seriously, where in the reference is the CEL code chart with a good detailed explanation on how to check CEL codes on the popular honda's?
    This seems like it owuld be a given to have on here. Hell, I didn't beleive my friend when he told me that he couldn't find it when he was checking his CEL's the other day.
    I am tooooooo lazy to mess with it, sorry. I'll just play informant. :p
    EDIT I was helping check codes on a Skunk2 Chipped P30 in a b16a swapped Del Sol S that looks just like B's car, only faster.
  2. E_SolSi
    http://www.hondaswap.com/forums/index.php?...?act=ST&f=1&t=6
    0 Faulty ECU (no signal)
    1 Oxygen sensor or circuit.
    2 Faulty ECU
    3 & 5 Manifold Absolute Pressure (MAP) sensor or circuit.
    4 Crank angle sensor or circuit
    6 Coolant temperature sensor or circuit
    7 Throttle angle sensor or circuit.
    8 TDC position/crank angle sensor or circuit.
    9 Crank angle sensor or circuit
    10 Intake air temperature sensor or circuit.
    11 No particular symptom shown or system does not operate - faulty ECU
    12 Exhaust gas recirculation (EGR) failure
    13 Atmospheric pressure sensor circuit.
    14 Electronic air control valve (EACV)
    15 No ignition output signal - possible faulty igniter.
    16 Fuel injector circuit.
    17 Vehicle speed sensor or circuit (VSS)
    19 Lock-up control solenoid valve (automatic transmission)
    20 Electronic load detector - possible open or grounded circuit in ECU wiring.
    21 VTEC spool solenoid valve circuit (Civic & Del-Sol)
    22 VTEC oil pressure switch circuit (Civic & Del-Sol)
    23 Knock sensor (Prelude)
    30 A/T control unit ECM fuel injection signal "A" (Accord & Prelude)
    31 A/T control unit ECM fuel injection signal "B" (Accord & Prelude)
    41 Heated oxygen sensor - heater circuit.
    43 Fuel supply system circuit (except D15Z1 engine)
    45 Fuel system out of range - rich or lean
    48 Heated oxygen sensor circuit (D15Z1 engine)
    50 Mass airflow sensor.
    61 Front oxygen sensor response slow.
    63 Rear oxygen sensor circuit voltage out of range.
    65 Rear oxygen sensor circuit malfunction.
    67 Catalyic converter efficency low.
    70 Automatic Transaxle problem.
    71 through 76 Cylinder misfires
    80 Insufficient EGR flow
    86 Engine coolant temperature sensor circuit.
    92 Evaporative emission purge valve problem
    *Please only use this as a guide* As some are different. This should only be used as a starting point.
  3. pissedoffsol
    http://hondaswap.com/reference-materials/88-ecu-error-codes-29109/
    Here's a handy chart for pulling your ECU codes. Pulling the code is a fairly easy process.
    For 92+ Honda's and 94+ Acura's:
    Before you can start reading the CEL (check engine light) in your dash, you need to 'jump' your ecu. Here's how.
    Located the factory two-pin connector of brown and black wires near the ECU on Civics del Sols and Integra's, or behind the center console for Preludes and Accords. Pull that 2-pin out of the main harness. Using a wire or paper clip as a jumper, connect the outputs of the harness together, so that the black wire and the brown wire make a circuit. Once this is jumped together, the dash will start the light show, so its a good idea to jump first, then turn to on.
    For 88-91 Honda's and 86-93 Acura's:
    The ECU's on these cars actually have a neat little window right on the computer case. No need to jump here- just turn it to on, and watch it right there through that window.
    For both steps above, the output will be in a Morse code style of long and short lights. For example, 2 long, pause, 3 short is 23.
    1- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98 86-98 97-98 85-91 93-97 95-98 85-98
    Oxygen Sensor "A" (Primary)
    defective circuit or unplugged / defective sensor
    2- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-89 86-87 n/a 85-87 85-91 n/a n/a
    Oxygen Sensor "B"
    3- Accord Civic CRV CRX Del Sol Odyssey Prelude
    MAP Sensor (Manifold Absolute Pressure)
    4- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 88-98 97-98 88-91 93-97 95-98 85-98
    CKP Sensor (Crankshaft Position Sensor)
    5- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98 * 86-98 97-98 85-91 93-97 96-98 85-98
    mechanical problem / disconnected piping
    * exc 94-95
    6- Accord Civic CRV CRX Del Sol Odyssey Prelude
    ECT Sensor (Engine Coolant Temperature)
    7- Accord Civic CRV CRX Del Sol Odyssey Prelude
    TP Sensor (Throttle Position)
    8- Accord Civic CRV CRX Del Sol Odyssey Prelude
    TDC Sensor (Top Dead Center)
    9*- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98** 86-98 97-98 85-91 93-97 95-98 85-98
    CYP Sensor (Cylinder)
    * not a valid code for any throttle body injection Hondas
    ** not a valid code for V-6 engines
    10- Accord Civic CRV CRX Del Sol Odyssey Prelude
    IAT Sensor (Intake Air Temperature)
    12- Accord Civic CRV CRX Del Sol Odyssey Prelude
    85-98 86-98 * n/a 85-91 * n/a 95-98 85-98
    EGR Lift Sensor (Exhaust Gas Recirculation)
    * not a valid code if car is not equipped with an EGR valve (some Civic models are not)
    13- Accord Civic CRV CRX Del Sol Odyssey Prelude
    BARO Sensor (Atmospheric Pressure)
    14- Accord Civic CRV CRX Del Sol Odyssey Prelude
    88-98 88-98 97-98 88-91 93-97 95-98 88-98
    IAC Valve (Idle Air Control)
    15- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-95 88-95 n/a 88-91 93-95 95 88-95
    Ignition Output Signal
    missing or defective ignition output signal
    16- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Fuel Injector System
    defective circuit or unplugged / defective fuel injector
    17- Accord Civic CRV CRX Del Sol Odyssey Prelude
    88-98 88-98 97-98 88-91 93-97 95-97 88-98
    VSS (Vehicle Speed Sensor)
    19- Accord Civic CRV CRX Del Sol Odyssey Prelude
    n/a 88-95 n/a 88-91 93-97 n/a n/a
    Automatic Transmission Lock Up Control Solenoid Valve
    defective circuit or unplugged / defective solenoid valve
    20- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 88-98 97-98 88-91 93-97 95-98 92-98
    Electrical Load Detector
    21*- Accord Civic CRV CRX Del Sol Odyssey Prelude
    94-98 ** 92-95 n/a n/a 93-95 n/a 93-95
    VTEC Solenoid Valve
    * not a valid code if car does not have a VTEC engine
    ** not with V-6 engine
    22*- Accord Civic CRV CRX Del Sol Odyssey Prelude
    94-98 92-98 n/a n/a 93-97 98 93-98`
    VTEC Oil Pressure Switch
    defective circuit or unplugged / defective oil pressure switch
    23- Accord Civic CRV CRX Del Sol Odyssey Prelude
    98 * 96-98 n/a n/a 94-97 n/a 92-98
    KS (Knock Sensor)
    * not a valid code if V-6 engine
    30- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 * n/a n/a n/a n/a 95 92-98 *
    Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB
    * not a valid code for 1996
    31- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-95 n/a n/a n/a n/a 95 92-95
    Automatic Transmission Signal "B"
    41- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-98 92-98 97-98 n/a 93-97 95-98 90-98
    Primary Oxygen Sensor - Heater
    circuit malfunction
    43- Accord Civic CRV CRX Del Sol Odyssey Prelude
    90-95 92-95 n/a n/a 93-95 95 90-95
    Fuel Supply System
    defective or malfunctioning fuel supply system
    45- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 97-98 n/a 96-97 96-98 96-98
    System Too Lean or Too Rich
    malfunction in the fuel monitoring systems
    48- Accord Civic CRV CRX Del Sol Odyssey Prelude
    98 92-98 n/a n/a n/a n/a n/a
    LAF Sensor (Lean Air Fuel)
    54- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96 96-98 97-98 n/a 96-97 n/a n/a
    CKF Sensor (Crankshaft Speed Fluctuation)
    58- Accord Civic CRV CRX Del Sol Odyssey Prelude
    98 * n/a n/a n/a n/a n/a n/a
    TDC Sensor 2 (Top Dead Center)
    * with V-6 engine only
    61- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Oxygen Sensor, Heated - Sensor 1 (Primary)
    high voltage, low voltage, or slow response
    63- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Oxygen Sensor, Heated - Sensor 2 (Secondary)
    65- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Oxygen Sensor Heater (Secondary)
    malfunctioning or defective oxygen sensor heater
    67- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Catalyst system Efficiency Below Threshold
    malfunctioning or defective catalyst system
    70- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 97-98 n/a n/a 96-98 96-98
    malfunction with the automatic transmission controls
    71- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 1 Misfire or a Random Misfire
    a condition is present that is creating a cylinder misfire
    72- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 2 Misfire or a Random Misfire
    73- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 3 Misfire or a Random Misfire
    74- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 4 Misfire or a Random Misfire
    75- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 5 Misfire or a Random Misfire
    * valid code for V-6 engine only
    76- Accord Civic CRV CRX Del Sol Odyssey Prelude
    Cylinder 6 Misfire or a Random Misfire
    80- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 n/a n/a n/a 96-98 96-98
    insufficient flow detected
    86- Accord Civic CRV CRX Del Sol Odyssey Prelude
    circuit range / performance problem
    90- Accord Civic CRV CRX Del Sol Odyssey Prelude
    97-98 96-98 n/a n/a n/a 98 97-98
    Evaporative Emission Control System
    leak detected in the fuel tank area
    91- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 n/a n/a n/a 98 97-98
    Fuel Tank Pressure Sensor
    low input
    92- Accord Civic CRV CRX Del Sol Odyssey Prelude
    96-98 96-98 97-98 n/a 96-97 96-97 96-98
    insufficient purge flow
    Are you done bitching yet? :)
  4. Slo86GT
    While we're all feeling helpful... anyone have a pinout for the 91 ECU harnesses?? :)
    THis is great. Ask and ye shall receive.
  5. pissedoffsol
  6. Slo86GT
    I get most of my info from my head, that I post. Articles are great when I need something, but to date, when LOOKING for info, not just browsing, I haven't been able to find chit I'm looking for. :p
