Alternator
Discussion in 'General Tech and Maintenance' started by Pewble, Jun 21, 2005.
  1. Pewble
    Pewble Senior Member
    im replacing the alternator in my 95 dx... it sucks ... anyone know of any guides on this i have a haynes but still having a bit of trouble
  2. sihatchback_RL
    sihatchback_RL Senior Member
    jack the car up, loosen the tension bolt, take off upper mount bolt, get under car and loosen lower bolt, remove belt. replace the belt.
  3. Pewble
    the belt is off... need to replace the ALTERNATOR
  4. 92dxhatch
    92dxhatch Senior Member
    nor*cal
    ....HELMS MANUAL....
  5. sihatchback_RL
    I know what you are replacing....don't take it out on us, we're just helping....the alternator is easier to take off than peeling a banana.
  6. Pewble
    ok i guess im st00pid
  7. Pewble
    Dangit beavis! my helms manual SUCKS for replacing alternator... i took off brackets and nuts and stuff all i need now is the last bolt that is under the alternator. the damn thing WILL NOT COME OUT ARRGHHHHH please help tell me how to get this facker out!! im about to take a sledgehammer to it.
  8. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    Why not put a pipe on the ratchet/wrench, thats why me and a friend did with mine yesterday.
  9. abdelsol
    abdelsol Member
    If you have removed all the other bolts there is probably additional tension on the one remaining. Put the others back in loose the problem child and then remove the others. oh of course as vetecpower mentioned a pipe is sometimes needed.
