power2weight
I am planning on getting a low compression B20B for my Integra. I want to force feed it junkyard turbo style.
My main 2 questions are will the Crower B18 non-vtec turbo cams work with the P75 head on the B20B?? I plan on using Crower's high perf valve springs and retainers also. 2nd, wich Skunk2 manifold is appropiate for a B20B in a gen 2 Teg?? Can I just use the B18A application?? I also heard the Crower cams like 1 degree of cam advance, if that is correct, is it the intake or exh cam??
thanks in advance
thanks in advance
