cycloneb18c3
ok, this isnt in a honda, but same thing as if it were!
I have a phoenix gold R5.0:1 amp(basically a 500 X 1)
I have the main power wire comming in (4ga) and it goes to a rockford fosgate 1 farad capacitor. it then splits off into 2 wires out(both 4ga), one for the phoenix gold amp(running subs) and a rockford fosgate amp(running highs). I have 2 JL W0's rated at 4 ohms. I wired these in parallel to get 2ohms. It is a 2 ohm stable amp. Main power wire is fused, with the fuse that came with the kit(i belive 60A fuse) the main powerwire fuse has NOT blown at all.)
now, the other day the phoenix gold amp stoped working. checked the fuses ON the AMP itself,(two 20A blade fuses) both of which were blown. I replaced them today, with another set of 20's and listened to the stereo at about 1/2 volume, and 1 minute later, pop, no bass, both fuses blown. I checked all the connections, and wires, and there cant be any shorts in the power wire. I also checked that the gain(bass) wasnt up too high, and it wasnt, because W0's are rated at 125 watts for optium power, so I had it set a lil less than half. after I made sure it was all good, I tried another 2 fuses, and 1 minute later of listening, pop, 2 fuses blown.
the rockford amp has worked perfect the entire time.
Help me! I got the amp as a gift for X-mas of 04, and I installed it in Jan. 05, so it isnt that old. My brother got it for me and he doesnt have a reciept(no warranty coverage!! damn him!)
what do u guys think?
