Amsoil Spin-On By-pass Filter
K2e2vin
http://www.amsoil.com/storefront/bf.aspx
Does anyone know if this is good for racing(doesnt mess with oil pressure)? They show iit installed on daily commuter vehicles but no weekend-race cars. Also, the "original" kit(BMK-11) they have the bypass filter mounted remotely; oil is tapped from where the oil pressure sensor is with a T-valve, and oil is filtered through the Bypass filter then goes back to the oil pan. They say only 10% flows through the bypass filter.
Well, on the Dual filter system(BMK-13) the Bypass filter is parallel with the regular filter, and the oil goes to the bypass filter first. wouldnt this be a bottle neck for the oil(more then 10% going through the bypass filter)?
The bypass filter is suppose to filter out smaller particles so im thinking its harder for the oil to flow through there.
Good concept- I would rather have the setup that replaces the filter in the stock location with the complete filtration system- that way you're always supplying the whole engine with the cleaner oil rather than just pumping it into the pan and hoping that your mix is cleaner than before.
:thumbsup:
:thumbsdown:
