another b18 crx queston from me
Discussion in 'HYBRID -> ED-EF / DA' started by LsB16CrxHF, Jul 1, 2005.
  1. LsB16CrxHF
    LsB16CrxHF Senior Member
    Massachusetts
    on the back of the block there are two sensors...thers pne the clips in and one that slides on...i have no idea what they are....what are they....lol
  2. hybrid89
    hybrid89 thistownsucks...
    SoCal
    I think you are describing the water temp sensor (lager w/2 prongs) and the oil pressure sending unit (single prong). they are the only 2 on an ls motor
  3. LsB16CrxHF
    Massachusetts
    well that plug for the water temp sensor is not on my harness for sum reason...woulda that affect how my car runs?....
  4. hybrid89
    SoCal
    yes it would defn affect how the car runs. what harness are you using?
  5. racintweek
    racintweek Senior Member
    Arlington VA
    it depends what year teh engine is, certain ls engines have 2 temp sensors (i'm not exactly sure which years though) . one on the back of teh block and one on the t-stat housing. if the engien has one on the t-stat housing use that one
  6. hybrid89
    SoCal
    The sensor on the thermo housing is the fan controller
  7. LsB16CrxHF
    Massachusetts
    my motor is a b18a1 (1991) and im using a 90-93 ls harness...i had sumone wire it for me for dx to mpfi....the person who wired it put the wrong connector on the harness for the sensor on the back instead of it being a femal connector on the harness it has two seperate slide on type connectors...so i take it im going to hafto wire a new one on there...?
  8. hybrid89
    SoCal
    yes, you need those sensors on the back. diregaurd the thermo sensor. you shouldn't have one, but make sure you hook up the 2 on the back!
  9. LsB16CrxHF
    Massachusetts
    one more thing....my car is having some idling problems tooo...could the unplugged temp sensor on the back be causing some of it
  10. hybrid89
    SoCal
    yes, alot to do with it. the ecu uses the reading from it to help measure the amount of fuel going into the engine at all times. it ha sno idea what temp the engine is running at. fix that first, then see where you sit!
  11. racintweek
    Arlington VA
    its just a sensor, the ECU turns the fan on
  12. hybrid89
    SoCal
    the ecu reads what that sensors is showing as a signal and determines when the fan need sto come on. but it not a water temp sensor...really
  13. racintweek
    Arlington VA
    thats what i use in my LS hatch, my temp gauge works, idle is fine, and my fan turns on.
