Another bug....
99sidude
Moderator
Moderator
VIP
My new swap is bogging/studering when I hit the gas at a lower rpm. Its like its misfiring, because it has shaky acceleration. It started around 350 miles after i finished the swap. I am not throwing any codes. Any idea what this could be?
My Setup:
93' eg hatch
obd1 b18c
p72
all stock except clutch, flyweel, test pipe (for now)
Changed the plugs and fuel filter....problem is still there
Maybe its the wires?
its a spark issue, i had the same problem and it was my wires. but at a lower rpm it will sputter and bog, but at a higher rpm it runs good right? if yes, then its a spark issue!
That it!!! I checked my plug wires over, and it looks like a little oil seeped through the 0-rings on the valve cover gasket.This must have shorted out the wire. Seems that I incorrectly seated them after changing my timing belt before the install. I went out, fixed that, and got new plugs. Everything is ok so far!
(knock on wood)
