Okay, this is not your average I don't have an idea what I'm doing and I can't start my car thread. I've done all the checks and everything is there. I have fuel, spark and compression but it still is only cranking and now I'm stuck as to what to do next. Any ideas?
The car is a 93 Prelude with a f22a engine.
There is definitely spark, I replaced the coil and module.
There is fuel - its actually floods the spark plugs and you can smell the gas from the tips
There is compression - one is slightly weak though, should still be okay right?
I don't understand what else is left?? Timing belt is okay too, it's not broken.
I even replaced the stupid main relay that everyone has a problem with.
Is there a fuel relay or something that might be causing it?
