Another Computer Question
Discussion in 'Members' Lounge' started by randerson165, Dec 23, 2003.
  1. randerson165
    randerson165 Senior Member
    Eugene, Oregon
    Every once in awhile my comp will restart all of a sudden. Is there a way to find out why ? is there an error message somewhere on my sytem that I could read from the shutdown ??? I don't think my comp is getting hot, the inside of my case is 82 F .......HELP
  2. Domeskilla
    Domeskilla Senior Member
    Fort Wayne, IN
    There was a virusa going around about 2 or so weeks ago that made your computer automatically restart, unannounced.
  3. randerson165
    Eugene, Oregon
    how can i check for this virus ? do you know what it is called ?
  4. randerson165
    Eugene, Oregon
    I don't have this virus, but I think something is wrong with my comp. I just turned off the automatic restart upon an error so know i will see a message and I'll let you comp. guys know what it says, maybe then you'll have more answers !!!
  5. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    i used to have a problem somewhat similar to this. my computer would just restart after while loading windows(winxp screen). --fixed with a reformat and reinstall of windows.
  6. pissedoffsol
    event viewer is your friend....
  7. Slo86GT
    Slo86GT Super Moderator
    Memphis - Hellhole of the South
    It could be that your PC reached a critical error and locked up, but your motherboard has auto-reboot logic circuitry, so it looks like it's just rebooting like you say...
    If you had NT/2000/XP there is an event viewer in the control panel, and you can research the error online...
    Otherwise, you're SOL.
  8. randerson165
    Eugene, Oregon
    well it seems to happen mostly when I'm playing a game and all of a sudden the screen will go blank and the system restarts.
    How can i view the event logger ?
  9. B16
    B16 Super Moderator VIP
    yay area, CA
    Start -> Run
    %SystemRoot%\system32\eventvwr.msc /s
    click OK
  10. Slo86GT
    From the sound of it, your PC is locking up, and it's rebooting itself. WarCraft3 locks up my PC sometimes, and my MB doesn't have the auto reboot logic crap, so it just sits there til I hold the power button down for 5 seconds to turn it off.
    It aggrivates me to no end, but I'll bet that's your problem too. Programming errors, or whatever causing the PC to lock up. I can leave the PC on forever and a day, and it won't lock up, even on WIn98, but every once in a while a game or soemthing that stresses the system somewhat cause data collision, and BAM. Locked up.
  11. randerson165
    Eugene, Oregon
    the event log said something about my atapi drive ??? is this my cdrom or harddrive ???
    it said:
    The device, \Device\Ide\IdePort1, did not respond within the timeout period.
  12. K2e2vin
    Raleigh, NC
    well what do you have hooked up to that port?(there is usually two ide ports; ide 0 and ide 1, ide 1 would be secondary)
  13. B16
    yay area, CA
    most likely cd rom, unplug it and see how it does.
  14. jeffie7
    jeffie7 Wrong Whole! VIP
    Maryland
    Thats called a Jody Computer =)
    So um did you buy a ring for Xmas? =) want me to tell April you don't want her anymore? shes gonna be sad
  15. randerson165
    Eugene, Oregon
    i have both my hard drive and cdrom hooked up to my secondary
    when i was installing xp on my system, it couldn't find my hard drive on the first ide port, so i just unplugged it and moved it to the secondary, worked fine and so i never have bothered to put it on the first one again
  16. Slo86GT
    No ring, not yet. Having one figured up and made, soon, actually... it's a pretty nifty design, I think you guys will like it.
    Anyway, tell April we're still on for right around April... I'm coming over to take a ride int he new Audi, of course! ;)
  17. randerson165
    Eugene, Oregon
    call the internet police, somebody hijacked my post... :boxing:
  18. jeffie7
    Maryland
    so let me get this straight you want me to drive my audi around with you and april in the back? hmmmm
    and about the ring don't do it! run!!!!! run!!!!!!!!! =)
  19. pissedoffsol
    your config sounds all fucked up....
    i'd suggest unpluging everything and starting over.
    set up like this:
    if you have 1 hdd and 1 cd rom,
    primary master- HDD
    secondary master - cd
    if you have 2 hard drives and 1 cd, or 1 hdd and 2 cds
    primary master- HDD1
    secondary master - CD1/HDD2
    secondary slave - CD2/CD1
    if you have 2 of each
    primary slave - HDD2
    seconday master CD1
    secondary slave - cd2
    verify cable position, and jumpers are correct for each position.
    plug everythign in
    98 boot disk to an A prompt
    formatthebitch.com
    re-install XP
  20. K2e2vin
    Raleigh, NC
    i did that and my hd-to-hd transfer rates sucked
    i read somewhere that the prefable setup is
    ide0 -hd1(main hd)
    cdrom1
    ide1- cdrom2
    hd2
