another dumb question!!
Discussion in 'HYBRID -> ED-EF / DA' started by etccatz, Sep 22, 2008.
  1. etccatz
    etccatz Junior Member
    ok so i got a pr4 in my hatch runnin an obd1 converted car. now with the stock ecu when its throwin codes its got the LED indicator light. now i got the pr4 in there how the hell do i read the codes that its throwin??? thank you ahead of time.
  2. D16SiHatch
    D16SiHatch New Member
    turn the key on and count the flashes
    Diagnostic Trouble Code (DTC) System Indicated
    0 Engine Control Module (ECM)
    1 Heated Oxygen Sensor (HO2S)
    3 Manifold Absolute Pressure (MAP Sensor)
    4 Crankshaft Position (CKP Sensor)
    6 Engine Coolant Temperature (ECT Sensor)
    7 Throttle Position (TP Sensor)
    8 Top Dead Center Position (TDC Sensor)
    9 No. 1 Cylinder Position (CYP Sensor)
    10 Intake Air Temperature (IAT Sensor)
    13 Barometric Pressure (BARO Sensor)
    14 Idle Air Control (IAC Valve)
    15 Ignition Output Signal
    16 Fuel Injector
    17 Vehicle Speed Sensor (VSS)
    20 Electrical Load Detector (ELD)
    21 Variable Valve Timing & Valve Lift Electronic Control Solenoid Valve (VTEC Solenoid Valve)
    22 Variable Valve Timing & Valve Lift Electronic Control Pressure Switch (VTEC Pressure Switch)
    23 Knock Sensor (KS)
    30 A/T FI Signal A
    31 A/T FI Signal B
    41 Heated Oxygen Sensor (HO2S) Heater
    43 Fuel Supply System
    1 person likes this.
  3. etccatz
    yeah but count the flashes on what?? there is no LED indicator on the ecu, and the CEL stays solid??? so thats why im wonderin how im suppose to read the codes.
  4. D16SiHatch
    i thought you said it HAD the light and you didnt know how to read it. wow thats my bad. from what i've read thus far it seems people are saying to jump the D4 ecu pin to ground, and it makes the ecu start spilling out codes by flashing the cel light.
    heres the obd1 codes btw.
    OBD1 Trouble Codes: Code 0 and 11 [COLOR=blue! important][COLOR=blue! important]Electronic [COLOR=blue! important][COLOR=blue! important][COLOR=blue! important]Control [COLOR=blue! important]Module[/COLOR][/COLOR][/COLOR][/COLOR][/COLOR][/COLOR] (ECM)
    Code1 Heated [COLOR=blue! important][COLOR=blue! important]oxygen [COLOR=blue! important]sensor[/COLOR][/COLOR][/COLOR] A
    Code 2 Oxygen content B
    Code 3 and 5 Manifold Absolute Pressure
    Code 4 Crank position sensor
    Code 6 Engine coolant temperature
    Code 7 Throttle position sensor
    Code 8 Top dead center sensor
    Code 9 No.1 cylinder position sensor
    Code 10 Intake air temperature sensor
    Code 12 Exhaust recirculation system
    Code 13 Barometric pressure sensor
    Code 14 Idle air control valve or bad ECM
    Code 15 Ignition output signal
    Code 16 Fuel Injector
    Code 17 Vehicle speed sensor
    Code 19 A/T lock-up control solenoid
    Code 20 Electric load detector
    Code 21 V-TEC control solenoid
    Code 22 V-TEC pressure solenoid
    Code 23 Knock sensor
    Code 30 A/T FI signal A
    Code 30 A/T FI signal B
    Code 41 Heated oxygen sensor heater
    Code 43 Fuel supply system
    Code 45 Fuel supply metering
    Code 48 Heated oxygen sensor
    Code 61 Front heated oxygen sensor
    Code 63 Rear heated oxygen sensor
    Code 65 Rear heated oxygen sensor heater
    Code 67 Catalytic converter system
    Code 70 Automatic transaxle
    Code 71 Misfire detected cylinder 1
    Code 72 Misfire detected cylinder 2
    Code 73 Misfire detected cylinder 3
    Code 74 Misfire detected cylinder 4
    Code 75 Misfire detected cylinder 5
    Code 76 Misfire detected cylinder 6
    Code 80 Exhaust recirculation system
    Code 86 Coolant temperature
    Code 92 Evaporative emission control system
  5. Korax
    Korax New Member
    Western PA
  6. etccatz
    so you are sayin its a jumper wire for the plug under the dash?? just like in a eg?? if so i pulled the codes from that with a paper clip. is there a wire behind the glove box just like eg's??
  7. Korax
    Korax New Member
    Western PA
    yep. There should be.
  8. etccatz
    alright that should be easy thanks.
  9. etccatz
    alright there is no wire behind the glove box that i can find. now can anyone be sure about jumpin the d4 to a ground?? i just dont wanna do it and fry something in the car. if anyone can vouch for it ill try it out or if you are totally sure that it works. thanks.
  10. D16SiHatch
    It should be on the far right side by the glove box, above the kick panel, assuming you have the switch. On some chassis it seems that this 2 prong connector is actually in the engine bay. Possibly by your driver side shock tower, or motor mount area.
    If you can't find a plug to use, like i said you can just jump D4 to a ground. I haven't personally done this, but others have.
    Honda-Tech.com: Honda CRX / EF Civic: retrieving obd1 codes
    Honda-Tech.com: Honda CRX / EF Civic: how to wire a switch to check obd1 engine codes...
    Honda-Tech.com: Honda CRX / EF Civic: How to read ecu codes with OBD1 conversion?
  11. etccatz
    alright. if i cant find the jumper plug i will ground out the d4 than. thank you very much for the help!!
  12. etccatz
    ok not to sound like an asshole now but which plug is the D plug?? it only has three plugs in the back of the ecu which i though was A, B, C?? and i found the plug by my shock tower jumped it and the CEL stayed solid??? does it have to be started or should it throw codes with the key just in the on position???
  13. D16SiHatch
    i realize this isnt for your ecu but you get the idea. the connectors are A,B, and D.
    GSR/ B16A OBD1 ECU pin out
    As far as reading the code like i said i haven't had to do it so i'm not certain. you would either have the car in the on position and jump the connector. or possibly you leave the car off, and then turn it to on with the connector already jumped. i'm not entirely sure.
  14. etccatz
    alright ill try that and let ya know whats happens. thank you
  15. etccatz
    ok now im confused. do i do the d4 on the jumper harness or the d4 on the stock harness??? and if its the one on the stock harness no wire goes to the ecu from the d4 plug?? if some one has a pick or anything that would be great. thanks again.
  16. cjvictoria
    cjvictoria New Member
    N. Chuck, SC
    not a dumb question, this in fact is a very common question that i hear from my friends ON A DAILY BASIS, so dont feel dumb for asking lol
  17. etccatz
    why thank you. its just i have played obd0 and messed with wiring stuff but this whole obd0 to obd1 is a little confusing. plus i dont understand why the kid wired and obd0 engine obd1?? it just dont make sense.
  18. cjvictoria
    N. Chuck, SC
    probly was all the dude could peice together lol
  19. etccatz
    nah he said that it was obd0 and he wired it obd1. plus he hacked alot of shit up. actually im not sure if he did but its pretty hacked up!!! still dont get it. i might just get a dx wiring harness obd0 dizzy and resistor box ecu and just go back obd0
  20. cjvictoria
    N. Chuck, SC
    sounds like a great idea
