ok i finally was able to pull the codes and i got nine quick flashes. now i know in the obd1 quick flashes mean ten but is that the same in obd0?? if so than i just have the cyp sensor. now if it is the cyp sensor what the hell is that?? if i get a manuel for the car what manuel should i get?? for the b18a?? and also if it is the code 90 what the hell is that code or is there not a code for that??? thank you ahead of time.
ok found out what the cyp is but i still need to know if nine quick flashes is still CEL code nine?? i cant find a code 90 so i would think it was 9?? if it is that would be great because thats the only code im gettin.
anyone??? also will the cyp sensor cause the car to not fire right?? i mean if i keep tryin to turn it over it will eventually turn over. but other than that it will just click and not even turn. will the cyp cause that also??
