another fucked LINUX / windows dual boot
Discussion in 'Computers, Games, Electronics etc' started by pills_PMD, Feb 3, 2005.
  1. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    well after working for a while, when i boot up windows from GRUB it loads eventually.. but takes a LONG ASS TIME to finally load up to the log in screen. it happened after i formatted a fat32 partition on the linux drive, which is physically a different drive than the windows xp OS is on.
    i use a dual monitor setup. the log in screen for windows shows up on the left screen and it takes a very long time before that shows after the "windows XP" logo screen w/ the scrolling blue bar goes across..
    any ideas?
  2. liquid00meth
    liquid00meth Senior Member
    Laconia, NH
    why fat32?
  3. projectxspeed
    projectxspeed Senior Member
    New Hampshire
    Are the the OS on seperate hard drives, or are they on seperate partitions?
  4. pills_PMD
    New Albany, OH
    completely separate hard drives... both western digital one 80 gb and one 160 gb
    80 holds windows, 160 holds linux partitions (all 3) and then a 120 gb partition that is formatted fat32 that mounts when linux is booted
  5. pills_PMD
    New Albany, OH
    because i run a dual system.. i need windows for certain programs i need for work and school.. and i wanted the 120 gb to be reachable from either OS
  6. CRX-YEM
    Wallingford, CT
    linux can read ntfs partitions tho
  7. pills_PMD
    New Albany, OH
    yea but not without a hassle. regardless.. this has nothing to do w/ my slow ass booting XP OS....
  8. phunky.buddha
    Dallas / Fort Worth, TX
    Have you tried to boot it without the Linux drive/partitions visible?
  9. Drake
    Drake Well-Known Member VIP
    If you can get your windows drive to load up, run defrag and disk clean up. If you have a bunch of extra crap on there try deleting that. But use add remove programs. Also how much Ram and what kind does your computer have. The way i understand it is that you have both os's running at the same time correct? If this is the case Linux dosnt have very steep requirements but Windows does for the most part. I can ask one of my buddies at school they might now. I hope you get it all worked out soon though. If I can think of any thing else ill let you know.
    Jeramy
  10. pills_PMD
    New Albany, OH
    they aer not both running at the same time.
