Another Shift Linkage Help Needed Removal Thread!
Discussion in 'HYBRID -> EG-EK / DC' started by Hybrid93Hatch, Mar 2, 2003.
  1. Hybrid93Hatch
    Hybrid93Hatch Member
    Cardomain.com is not allowing pic uploads until Sunday (tomm.), so I am having to upload them to geocities.com
    Ok, here are the links to the pics I took of my shift linkage. I have looked on c-speed racing and mine seems to look different than theirs.
    Please feel free to upload the pics to a site that allows direct linkage and add text to explain what the hell I am suppose to do.
    My goal today before going to work was to get the exhaust disconnected and the shift linkage out. I got the exhaust (2 bolts WOW ) and the shift linkage is still intact.....
    http://www.geocities.com/lx98civic/SwapDay01.html
    Click on the pics to make them larger..... Save and add text as needed please
  2. pills_PMD
    pills_PMD Super Moderator
    New Albany, OH
    use hondaswap yO! click on the gallery is open link
  3. SnailOnARampage
    SnailOnARampage Senior Member
    Utah
    One of them is just a bolt you can unscrew, and the other is a rivet. Apparently honda thought they could save 6 cents by putting a rivet in one of the D series shift linkages. You have to get a grinder and grind one end of it off (I ground the driver's side). If you plan on putting it back in you just need to put it back together and weld it in.
  4. rex2nr
    rex2nr Junior Member
    if you are talking about removing the linkage from the tranny, slide the rubber boot back, pop off the clip. You should see a pin that is pressed in. Take a long extension, or 2, place a screwdriver attachment on the end with a philips bit, put this in the pin (its hollow) and beat it out with a large hammer. once it gets down far enough, take the screw driver attachment off, slide a bolt in the hole, place a socket that will fit the bolt, and drive it out the rest of the way. should take you about 10 minutes that way :D
  5. MR. EG
    MR. EG Member
    also if you are palnning to re connect the shift linkage, which you probably are, you need to save that little pin he said that you need to pound out. you will need it again. i know that this is a no brainer but my friend bent his and was severley fucked until the next day when he could get another
  6. pissedoffsol
    right- just get a bolt or a tap about the same size, and GENTLY hammer it out.
  7. rex2nr
    can't you just put a bolt in there? I saved my pin, but I've heard you can do that
  8. EkHatch
    EkHatch Junior Member
    try this, this is a really easy way to remove the infamous "EVIL PIN"!!
    if you have or ever had A/C on your engine, take one 12mm bolt from the a/c bracket, it should be a long, skinny 12mm bolt with a point on the end, this is perfect. now get a hefty hammer, I use a 10lb sledge.. place the bolt onto the evil pin, and pop it, it should go all the way thru the linkage and pop out on the top! you can use this same bolt to pop it back in
    good luck
  9. chris
    chris Senior Member
    nihon
    the bolts to the header and cat also work, nice lil extended tip that fits perfectly
  10. HerunurlUnate
    HerunurlUnate New Member
    Hey I'm new
    What's up everyone, I'm new to the forum and just wanted to say hey. Hopefully I posted this in the right section!
  11. MarkoBatelicic
    MarkoBatelicic New Member
    Please Help with Generic Viagra Spam what can i do about this
    Hey guys, sorry if this is wrong section or place to ask but maybe someone can help me. My forum just got bombarded with viagra spam, what can you advice me please what tools can i get to stop it? [​IMG]
    I was trying to google something about this but with no avail. Sorry to bother but really need some help with this.
  12. Nstygrnhatch
    Nstygrnhatch K swapped Member
    Ruther Glen, VA
    I have a snapon tool that is specifically shaped just for the bitchpin. Works with a air hammer. I will get a part number tommorow
  13. jgpoirier
    jgpoirier New Member
    Im right in the middle of a D series to B20. Easiest way took me less then a minute.
    Take a large punch that is the same size as the bitch pin itself, all I have heard that pushing the pin out from the center of it fucks it bad sometime. I got it about half way out, cause of the tapered shaft on the punch. Then took a small punch and tapped it twice and she came out.
    I have heard that putting something inside of the bitch pin almost always spreads it outwards and renders it unsuable.
