Another v-tec question
Discussion in 'General Tech and Maintenance' started by mozzandherb, Sep 27, 2005.
  1. mozzandherb
    mozzandherb Senior Member
    This question is really vague, but I was just wondering at what rpm's does v-tec usually kick in where you know or feels it's working?
  2. VTECPOWER
    VTECPOWER Senior Member
    Winchester, VA
    What car/engine? If you have mod's you can hear it cross over, usually on a dohc vtec with a short ram/CAI you are good to hear it, on a sohc vtec its a little harder to hear, but possible.
    What is the point of this question?
  3. mozzandherb
    It's an jdm h22a from a 93 lude. Mods are i/h/e and a few others, and that's my question at what rpm's can you hear it cross over?
  4. DesertDx
    DesertDx Junior Member
    The '99 lude that I was just driving crosses over around 5500, and as far as I know it is pretty stock other than i/h/e.
  5. reikoshea
    Dallas, TX
    mine it is 5100-5300 just after 5k is what im saying.
  6. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    It should be around 5300 rpm. It's very noticeable.
  7. formby
    formby learning in progress
    the sound will be louder with IHE; however a properly tuned engine will have a straight powerband so vtec wont kick you in your seat...youll only hear it..or notice a surge in rpm velocity
  8. B16CRX
    B16CRX Senior Member
    Greenville, SC
    run open header and ge ton it once. you will hear it. It will make a loud pop sound and be much louder than normal.
  9. drpenguin
    drpenguin Senior Member
    Salem, Or
    5g on the dot for my b16
  10. eg6sir
    mine is very noticable when vtec engages..its loud as hell...i'm not sure if its normal to engage at like 5800 rpm...i'm running the USDM p30 ecu obd1..i have a JDM ITR intake mani. & TB..CTR cams...DC 4-2-1 header....2 1/4 catback..is there a better ecu so vtec hits earlier/ harder?...just curious..
  11. reikoshea
    Dallas, TX
    you need to chip your ECU becase that thing definitely aint tuned right. if you have anyone with a dyno and tuning exp, take your car to them...its needs some TLC.
  12. eg6sir
    if you are refering to me...my ecu is stock...i dont want to chip this ecu...i will buy a diff. ecu for chipping purposes...which one do you recommend..
  13. formby
    the p30 is fine or a p28...you can chip either
  14. eg6sir
    seeing that the USDM p30 is so rare and worth a little bit of cash, i'm gonna leave it alone, someone may need it....about how much do p28 or jdm p30 cost normally...or if someone on here has one chipped already..
    i'll look around on here
  15. reikoshea
    Dallas, TX
  16. B16CRX
    Greenville, SC
    you can get a P28 from a junkyard for $50.
