ANTIFREEZE BOLT
Discussion in 'General Tech and Maintenance' started by Jazzy19, Mar 28, 2004.
  1. Jazzy19
    Jazzy19 Senior Member
    B18B ENGINE........BOLT ON THE ENGINE BLOCK(*WHERE YOU BLEED THE ANTIFREEZE) BROKE IN HALF......... How do i get it out cuz i have a steady stream of antifreeze coming out from it......please help me!!!!..... What else could i do to fix this problem
  2. Jazzy19
    can anyone help me....could i seal it up????? what should i do in this case!!!!!
  3. civic_types
    civic_types Senior Member
    Stop the car !
    Tap the bolt out
    Replace it
  4. StyleTEG
    StyleTEG Senior Member
    Yeah, EZ-Out and replacing it would be the best method.
    You could also simply JB Weld the hole shut. It should hold under the temp/pressure.
  5. reckedracing
    reckedracing TTIWWOP VIP
    NY
    uhm, tap it and get a new bleeder...
    is it a replaceable part, or does that bleeder go direct into the block?
    if you drill and tap makes sure you don't get metal in your motor...
  6. JDMilan
    JDMilan Senior Member
    Boca Raton, FL
    band aid??
    yeah, what the others said..
  7. Jazzy19
    well the bleeder is on the block of the engine......I dont want to tap it out n have metal in my engine.....is there a for sure solution for this problem???
  8. nfn15037
    nfn15037 Senior Member
    Get an easy out from sears, back it out and replace the bolt like everyone said, the easyout won't make really hardly any metal shavings. I guess you could do it with the car on, so the positive coolant pressure keeps crap out of the head?
  9. 97hatch
    97hatch ?
    Anderson IN
    it is on the water neck if im thinking right and it that is the sase take it off tap it and replace if cant fix go to the junkyard and get whole water neck
  10. cws13
    cws13 Senior Member
    Athens,GA
    Do not do this or you will melt your coolant-less engine and/or possibly face. Jesus. :roll: Cooling jackets don't touch anything important and a few shavings won't destroy a water pump. Is it on the waterneck? 12mm nipple? They crack if you overtighten them. You can get some hondabond and a matching bolt to block it off completely until you get a new neck. If it broke going in then an easy out will do the trick, if it broke coming out them probably not.
