Cashizslick
!i!i!i!i!i!i!i!i!i!i!i!
sell the CAI, for a stock one plus cash
i'm too old for this game
I heard the stock one performs very well on the 350. Stock box + comptech filter or something to that effect.
my first order would be to re-install the factory springs back in it
if you want to fill in the wheel well get yourself a little bigger sidewall for a more comfy ride lol
scrap the rear coilover and camber kits
but nice buy man, glad you didnt get the salvage title one and found one you liked in black
it's actually negative in the front and within limits in the rear, the opposite of what you said...
he guy kept the stock shocks and dropped the vehicle with some lowering springs. The wheels will depend on the weight mostly, but some nice wide rears would be tasty.
What are your thoughts on 17" wheels? Maybe I suck in "B Series Land" but 18" wheels just seems a tad bit much, if you can get an equivalent total diameter with a smaller wheel and biger tire it seems like it would help.
I heard you on the bolt-ons, already looking, may just go NISMO.
Thoughts on the whole "Stage Two Chip" thing? I dealership was trying to sell me an 05 ase model, kept talking about how the chip would negate the power difference in the 06 model. I have never messed with chips, to me it is the kind of thing rednecks do to their F-150's but maybe I am missing the boat on this. I want to go NA, if I can get it around 350HP I will me more than happy.
Headers, highflow cat or test pipes, exhaust, spacer, and chip. If I do all that, keeping the CAI, what am I looking at Jeffie?
I think I may be the last "OG" hondaswap member to cut his ties with the big H
You May Be An "OG" Hondaswap Member If:
-you don't actually own a honda/acura
-you understand "Flagday""
-if you have actually seen the flash intro for the website
-if you ever posted with "pissedoffsol"
-if you know Triniti
-if you know about "V-Tech"
Did I miss anything?
None of this applies to me
Why do I need an Oil Catch Can?
Lets look at your engine for a moment. Every engine during the normal combustion process, has blow-by. Engine Blow-by is excess combustion gases that leak by the piston rings and escape into the engine crankcase. During each compression or power stroke of a normal engine cycle, a very small amount of gases leak by the piston rings. This happens because the piston rings do not create a perfect seal. This Blow-by of gases is very small, but the higher the RPM and the more pistons, the more the blow-by starts to create pressure in the crank.
This pressure needs to be released, and is done so by crank case vents. Because manufactures have to keep environmental issues in mind, these gases can’t just be vented to atmosphere. So the OEM’s vent these gases back to the intake system to be re-burned. This all sounds good, but Blow by is nasty stuff!
Engine blow-by contains gases and oil from the crankcase. The gases aren’t really a problem, but the oil is. This oily mess coats everything in its path as it makes it way back to the combustion chamber. This nasty oil mess gets into the turbo, then boost tubes,then intercooler, into the intake manifold, and finally back into the engine. As the oil creeps in between couplers and boost tubes, it can cause the connection pop off under boost. This oil then gets into the intercooler, coating all the cooling fins. This greatly effects the ability of the intercooler to cool, and the efficiency of it will drop! This will cause a huge loss in power and can cause detonation. The last place this oily mess sees before the combustion chamber is the intake valves. Because of the temp differences and the oil impacting them, the oil will start to build up and form sludge. This adds up over time, and can cause many other problems, and hurt performance.
From this you can see, blow-by is bad, and it needs to be dealt with.
Do you also have a breather tank?
