Hey guys, does anyone have the Edelbrock Performer X turbokit? Its supposed to be one of the most complete turbokits on the market boasting 60% increase in hp with 6-7 psi. Heres some info from their website:
Performer-X Turbocharger System
Note: Fits Models with D16Y8 Engines Only
This complete and simple to install turbo kit gives D16Y8 SOHC Vtec owners an option to costly non-emissions legal engine swaps. The Garrett T28 ball bearing turbo comes pre-assembled as one unit with a Ni-resist cast exhaust manifold and a cast iron exhaust elbow for the simplest possible installation. A windshield pillar mounted boost gauge, o-ring seated flanges, a turbo oil supply adapter, and pre-assembled Russell oil, water, and fuel lines (no adapters or hose clamps) are also included in the package to make this one of the most complete kits on the market.
A high-performance Performer-X intake manifold with four extra injectors and a separate electronic controller are used as a means to supply enough fuel for the Vtec motor. The Edelbrock exhaust manifold and elbow are designed for maximum flow at high velocity for quicker turbo spool-up. Dyno tested output at 170 horsepower versus 105 horsepower at the wheels on a stock Civic, a 60% increase in power at 6 to 7 lbs. of boost with Performer-X kit.
Complete Kit Includes
Garrett T28 Ball Bearing Turbocharger
Edelbrock Designed Exhaust Manifold
Ceramic-Coated Steel Tubing
Tial Blow-Off Valve
Edelbrock Performer-X Intake Manifold
Over-Sized Spearco Intercooler
Cone Style Air Filter
Russell Oil Lines & Fittings
Windshield Pillar Mounted Boost Gauge
HP & Torque: 170 HP/140 ft-lbs Torque
Installation: Typical installations can be done in 16-21 hours. Performer-X Turbo systems are engineered for true OEM quality fit.
Ive seen prices from $3500-3800. Let me know if theres any feedback or interest in a kit like this.
Tial Blow-Off Valve
