Anyone Have Suggestions For Me?
Discussion in 'HYBRID -> EG-EK / DC' started by StealthMode, Mar 12, 2003.
  1. StealthMode
    StealthMode Kung Foolin'
    Thornton, CO
    i just recently got a car, and i'm 16. (please no one rag on me for knowing nothing) but i just wanted to know what would be the best setup for my 94 civic cx. (isn't this the lightest one?) let me know.
  2. rsaeini
    rsaeini Senior Member
    Los Angeles, CA
    Welcome!
    You pretty much have endless options. Any B-series will bolt right in. Take your pick(B16, B17, B18, B20).
    You can throw a H22 in there as well if you really want.
    What are you going to do with the car?
    Estimated swap costs(parts and labor):
    B16a2,3 = $2200-3000
    B18a/b = $1000-2000
    B18C1 = $4000-4500
    B18C5 = $5000-5500
    H22 = $3900-4500
    B20/Vtec = $4000-4700
    Link on the line below and read the articles, that should atleast get the gears turning. :
    http://www.hondaswap.com/swap/info.php
  3. StealthMode
    Thornton, CO
    (if anyone will even look at this)
    i want to put a B18 in. pretty basic ideas here, i don't know a whole lot. intake, cat-back exhaust, mainly the things to keep the B18 running. but my car's red, and i want to get some black 17's (lightweight) and a black carbon fiber hood, wrap-aroung spoiler, bodykit. thanks for the advice.
    :ph34r:
  4. lsvtec
    lsvtec GNU/Linux Evangelist
    Greater Portland, OR
    Skip the kit and the wing, that money will buy you a better valve train for you B18. Go with some 15" rims instead. IMO 17s look goofy on a Honda.
    Which B18 are you looking at?
  5. StealthMode
    Thornton, CO
    shoot man i don't know. a good one i hope. i don't really know much about all this yet. but i don't necessarily want to get my new engine absolutely RIGHT NOW. first off i don't have the money for it, (i'm 16 and make $9.18/hour and only work like 12 hours a week until summer {pool lifeguard}). so not too many options yet. but i also want my car to look nice, but i don't wanna go overboard cause people will think my car is fast and it won't be and that's weak. plus my car only has 140k miles.
    only time can tell.
  6. StealthMode
    Thornton, CO
    also what's the difference between a B18 a/b and a B18 C1?
    the cost is significantly higher for the C1, but what's the difference in performance and maintenence?
    :ph34r:
  7. lsvtec
    Maintenance is not much different change your oil regularly, keep coolant in it, you do have to run higher grade gas though. But the C1 performs much better. 10:1 compression and VTEC paired with a tighter tranny.
  8. E_SolSi
    the best advice i can possibly give you is this:
    the first thing you sould invest is, time into RESEARCH
    this will save you from wasting money on parts that dont doo much if anything at all
    this will also save you from getting the wrong parts for your goals
    i put about 2 years into planning my project (im OCD as hell) i am happy as hell with every thing i have now
    you dont need to put quite that much time into it but the more time you spend the less money you will waste
    research research research
  9. pissedoffsol
    i agree.
    ASK a whole lot here, buy later. As long as you post with an open mind and admit to not knowing anything, people will help you out.
    its the arrogant fucks that come in talking shit about how they want to run 10s on NAWWWWS and still don't have a clue.
    now, as far as your car goes- what do YOU want out of it?
    do you intend to race it? if so- what kind? autox, drag, road course? etc...
    or, do you just want a daily driver with a little more pep?
    or, do you want to be a street racer and win mad hunnies y0!
    (we don't promote street racing here)
    but, if you want to build your car for that, we can guide you through.
  10. StealthMode
    Thornton, CO
    well i think i'm going for the everyday driver with more pep. i mean, it's not like i can afford 2 cars and build one up for only racing. of course i would like to take it to the high school drags or race it sometimes, but mostly it would be for everyday use. so it seems like the B18C1 would be the best bet, cause it has the vtec. thanks a lot. this really helps.
    so what else would i be looking at when i want to put the B18 in? (extra parts, etc.)
    :ph34r:
  11. pissedoffsol
    I'd suggest the GSR swap for you as well. it has better off the line power than a b16 does due to more lower torque - and that helps you get going.
    to get the gsr into your 94 cx, you need a couple things.
    assuming you get the COMPLETE 94-95 obd1 GSR swap,
    in addition, you will need:
    IAB wires (for the butterflies in the intanke maifold.
    convert to 4 wire O2 sensor
    VTEC solenoid and VTEC pressure wires
    add knock sensor wire (well, depends if you decided to use the p72 gsr ecu, but you should)
    94-95 gsr upper radiator hose
    94-95 del sol vtec lower radiator hose
    94-95 GSR throttle cable
    if you want a/c (which you probably don't have anyway) you need a del sol vtec 94-95 a/c mounting braket
    other than that, it will drop right in =)
    it sounds like a lot of custom shit, but its really not that bad at all. just be prepared to spend the extra cash- the oem honda parts add up fast.
  12. StealthMode
    Thornton, CO
    thanks, is the GSR a B18, or what?
    i was also thinking about the B20vtec cause the price range is about the same as the B18C1. all that seems pretty easy to do (or have done :blink: )
    but where would i usually be able to find all the stuff. would i have to go to a salvage yard (which i don't think would be the best) or would i have to order them.
    (surprisingly i DO have a/c)
    how much do you think the gsr and other parts would cost me?
    :ph34r:
  13. DazedCivic99
    DazedCivic99 Senior Member
    Florida
    the gsr is the b18c1
    the type r is the b18c5
    to do the b20vtec you need some understanding of engine work and what not
    you can find some stuff probably in junk yards but would u trust some of the stuff out the the yards? looking on ebay you can find stuff
  14. xj0hnx
    xj0hnx I wanna be sedated VIP
    C.C.TX.
    I have never understood people who say stuff like this.Where do you think the motors people order come from?People don't drop off their used cars at the exporter and say "there you go".They are salvage motors and parts.
  15. DazedCivic99
    Florida
    yea true i just thought about that some more, like anything that i get i would see how it looks and decide from there, good point there
  16. xj0hnx
    C.C.TX.
    Yea,it is always better if you can see parts beforehand.
  17. TRuggiero_
    TRuggiero_ Senior Member
    Winter Garbage, Fl
    You should sell your CX and buy a Skyline yo! But if you wanna go the cheaper route, B16A. I like the B16A, it's a damn good motor, it'll drop in easier than the GSR motor, you won't have as much power but it's cheaper and can easily be stroked to 1.8 liters.
  18. xj0hnx
    C.C.TX.
    For the price of a stroker kit,he could pay some else to put the B18C1 in his car.
  19. Baker
    Baker Senior Member
    Schaumburg, IL
    ok, don't mak ethe huge mistake many people do at 16, if you are serious save your money and do a swap. don't but random parts an engine will be the best thing you have ever spent money on. Asking questions here is good I'm sure I annoy everyone since I ask like 9 questions before I'll buy any part but since coming here I've been happy with everything I've bought.
  20. pissedoffsol
    not even close. the b20/vtec will cost you about double.
