anyone have this problem.
Discussion in 'HYBRID -> EG-EK / DC' started by 904drB20B, Dec 2, 2008.
  1. 904drB20B
    904drB20B New Member
    b20b with a s1 tranny, i got the flywheel and clutch for a 98 crv and my pressure plate doesnt line up with the flywheel????? :confused: not that anyone with an eg-ek/dc would run a cable transmission :huh: but any info is greatly appreciated :D
  2. D16SiHatch
    D16SiHatch New Member
    you need the flywheel and clutch for the transmission you have, not the engine it's mated to. so you do have an ls cable trans then? if so you need to be certain whether its 90-91 or a 92-93. the later model years had a 1/16" larger input shaft on the trans, so you have to make sure you order the right year clutch kit. flywheels so far as i can tell from all b-series are interchangeable
  3. 904drB20B
    okay thanks for the help i got a clutch kit for a 91 integra, well see if it does the trick. thanks again.
