Anyone w/ a sir I have problems w/ emissions?
totalburnout
Well-Known Member
VIP
Okay, it looks like I'm very very close to getting a '95 Si HB swapped with a sir I in it. The car is converted to obd1 so the sir I could be run. I live in the fuckass state of New Jersey and wanted to know if I would have trouble passing with this car.
Originally posted by khai_tuan_nguyen@Aug 24 2004, 04:15 PM
Both your car and motor are obd1, so as long as the actual emissions is normal you will pass.
Khai
[post=381120]Quoted post[/post]​
...even though the car is a USDM spec car, and it now has a JDM spec engine it'll pass?
If this helps at all, the motor is a sir I run with a sir II ecu.
