apexi turbo timer
Discussion in 'ECU's, Electronics, and Tuning' started by boost_fed_ef, Aug 6, 2005.
  1. boost_fed_ef
    boost_fed_ef Member
    anaheim hills, ca
    im trying to install the apexi turbo timer... i can run the ebrake line o2 line and ground... the 12volt ignition wire is easy (red wire) but where exactly does the blue and green wire run too... need help desperatly
  2. pissedoffsol
    apexi-usa.com has downloadable pdf's of their instructions for install.
