Apexi V-AFC 2 initial settings
Discussion in 'ECU's, Electronics, and Tuning' started by 3D HONDA, Jul 7, 2006.
  1. 3D HONDA
    3D HONDA Junior Member
    Bonnie Scotland
    Okay my fellow honda friends have just got my vtec controller today and have wire it up and me being me i have just realsied that i dont know my
    Sensor number?
    Setting vtec type ?
    throttle sensor voltage ?
    the specs of the car are
    1994 honda accord es
    h22a engine swapped in from a 2.2 vtec prelude
    p13 ecu
    no traction control
    using stock 2.0l harness with plugs added in
    engine is in full working order please can you guys help me out as im lost at the moment cheers
  2. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    If your engine is stock, and you are using a stock ecu, you shouldn't need the VAFC. Regardless. I have never used used one, before, and am not familiar with it.
    So you need:
    Sensor number - Which sensor? MAP? TPS? ECT? IAT?
    Setting VTEC type? What choices does the VAFC give you to choose from?
    As far as TPS voltage, I think it's 0-5V, but not 100% sure.
  3. 3D HONDA
    Bonnie Scotland
    all it says in the book is sensor number then
    in n ouut way a number under each
    the vtec type is an option 1,2,3 to do with rev bands
  4. raidmax
    raidmax New Member
    East Coast
    Download the Manual from here.
    Sensor number should be 06 / 06
    VTEC Type is on page 49
    throttle sensor voltage is on page 51
