Are more expensive cooling fans worth the money???
Discussion in 'General Tech and Maintenance' started by BigBoy, Feb 15, 2006.
  1. BigBoy
    BigBoy Senior Member
    cali 818
    for example the ones that go for 2-3 bills...will i see any type of performance gains compared to getting a 50 dollar one from pep boys?
  2. K2e2vin
    K2e2vin Senior Member
    Raleigh, NC
    I would say no unless you're having overheating issues with your current setup or have a high-output engine.
  3. BigBoy
    cali 818
    the descriptions state it frees up 17 hp by moving more air. So its all BS?
  4. K2e2vin
    Raleigh, NC
    Yea it's bs. The radiator effects the cooling system by simply expelling heat into the atmosphere and transfering ambient air temp to the coolant; if your stock cooling system is working fine and keeping the temps at the optimal range, then you won't notice any gains from an aftermarket radiator.
  5. GSRCIVICTN
    GSRCIVICTN Lost in a sea of rednecks
    Nashville, TN
    He was asking about the cooling fan. The same still goes for the fan in the same way he described the radiator. You won't free up 17 horses. Shenanigans! [​IMG]
  6. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    ya see that might be truse on a belt driven fan but not on a honda with an electric fan bs
  7. MikeBergy
    MikeBergy Blah blah blah....
    Central Coast, CALI
    bs. I'd only buy a new fan, spec. a FAL fan, if I had a turbo, and there wasn't enough room for a stock one. If you are having cooling problems, you most likely need a larger radiator. The fan is just there to get the forced convection going when you are stopped.
  8. jimboburgess
    jimboburgess Go fast, Go Cheap
    nyc
    that was my problem i would only get a fan such as the type being discussed here if i needed to make room for something.
    or if my engine was over heating and that was the problem
  9. GSRCIVICTN
    Nashville, TN
    If your engine is overheating, you have cooling system problem. Replacing the fan won't fix a thing unless the fan wasn't working at all and you were overheating when sitting still or at very low speeds.
