Are the sensors different? Need Help?
Discussion in 'HYBRID -> EG-EK / DC' started by Som1Dies2Nite, Jun 10, 2005.
  1. Som1Dies2Nite
    Som1Dies2Nite Member
    Would the IAC, IAT, MAP be diffeferent?
    The car does not have a check engine light lit idles high @ 1500rpm smokes black when reving. With the IAC disconnected it idles @ 600 or 700 rpm and still smokes rich? Whats goin on?
  2. brian11to1
    brian11to1 Senior Member
    i know there are 2 plugs the same, not sure which ones.
  3. formby
    formby learning in progress
    what ecu are you running??????????
