brian11to1
Can this be installed with the engine still in tact or does the engine need to be torn down and ARP rod bolts installed?
Originally posted by pissedoffsol@Apr 18 2005, 12:11 PM
you need to pull the Valve cover, and cams
[post=488297]Quoted post[/post]
Originally posted by pissedoffsol@Apr 19 2005, 08:57 AM
bah, im an idiot. i read this as head studs.
lol
naw, just drop the oil pan, windage tray, and there you are. remove the ( and the two bolts. put the arp bolts on the ( cap and tighten to spec.
[post=488648]Quoted post[/post]
Originally posted by brian11to1@Apr 19 2005, 09:03 AM
I knew it. Ok, I was told something had to be machined for em to fit or some shit... what about rod bearings?
[post=488652]Quoted post[/post]
