arp studs for lsvtec
Discussion in 'Engine Building' started by bigg86, Mar 17, 2008.
  1. bigg86
    bigg86 New Member
    which ones do i need to get? i'm building an ls/vtec with a gsr head.... i cant remember if i need to get the studs for ls or gsr for this set up....
  2. jOnZ
    jOnZ JDM jOn
    I believe you go with whatever head your using.
  3. Superwho05
    Superwho05 New Member
    Dallas
    I agree with jonz. when I built my ls vtec with a b16 head, I bought arp headstuds for a b16 (which is the same generally for all b series vtec heads if Im not mistaken)
  4. bigg86
    bigg86 New Member
    yeah that sounds right... thanks guys
  5. armluv
    armluv New Member
    Hawaii
    I just got done with a ls/vtec swap. the arp studs you need are the Acura VTEC HSK Studs part #208-4303. hope that clears things up for you.
  6. ls/vtechatch91
    ls/vtechatch91 New Member
    washington
    ya gsr head studs i used stock ls ones on my ls/vtec with a b16 head.. but after i got my head built a bought arp b16 studs
