ARP Studs
Discussion in 'Engine Building' started by Celerity, Jun 29, 2005.
  1. Celerity
    Celerity Well-Known Member
    ok, I got the ARP stud kit for Nitrous setups. It's a 10 stud kit, with an included 3/16th allen key. Of course you can't torque it down with the allen key, so I have a Great Neck hex socket, on a 3/8" drive indexed torque wrench.
    And it's rolling in the stud ! What the hell ?! At about 50 pounds it strips out the tool and begins to harass the stud. What is going on here ? Is there something I'm missing ?
    It has to go to 70 lbs /ft.
    -> Steve
  2. 94CivicSlow
    94CivicSlow Senior Member
    B0ST0N
    Headstuds or main studs...
    ARP specifically says to install the studs hand tight.
    Theres a 12 point nut that you're supposed to torque not the allen!!
  3. matts91hatchls
    matts91hatchls Member
    elizabeth nj
    i cannot beleive that you tqed down the studs into the block... i just put a small vice grip on mine and send them for a spin untill they stop....
    good luck i hope you didnt do any dammage to the block,,, if the engine is out of the car then get it checked for cracks around that area... if its in the car give it a good eye and cross your fingers and hope for the best
    you are supose to tq the nut that came with the studs down to 70ft/lbs on top of the head to hold it down
  4. civicious
    civicious FüK-VTEC VIP
    Houston, TX
    You torqued the stud into the block? Wow...
  5. 94CivicSlow
    B0ST0N
    You mean block... Ya thats retarded. Stop playing with cars
  6. pissedoffsol
    :owned:
    i'm shocked as well. even I never did that....
  7. Celerity
    There are two sets of instructions, one for the stud installation and the other for the nut torquing. Studs distinctly state, with the ARP lube, to go to 70 lbs/ft. The nuts are going to 75 lbs/ft.
    94CivicSlow: Thanks for nothing, Your post has enlightened the ever living shit out of me.
    I'll just call ARP direct.
  8. 94CivicSlow
    B0ST0N
    I, unlike you know how to install the stud kit and didnt break my "Great Neck" tools in the process, jackass. Studs are to be installed HAND TIGHT. BY HAND.
  9. civicious
    Houston, TX
    :owned: on top of :owned:
  10. civicious
    Houston, TX
    Such an awesome image
  11. abdelsol
    abdelsol Member
    I think you need to read the instrustions again. You are being flamed because it make no sense to torque studs. Per ARP the recommended torque provides 75% of the yield of the fastener. If you torque the stud and then the nut you would exceed the yield of the stud and the tap in the block.
    This is per ARP's web site....
  12. Celerity
    alright alright alright alright I was fuckin owned.
    -> Steve
    Head is on now, tight as can be.
  13. sohcslammer
    sohcslammer Senior Member
    Bay Area
    :thumbsup:
    Hey, sometimes it happenes to the best of us.... :D
