atomesque car
Discussion in 'Other Vehicle Discussions' started by VTEC_CBR, Jan 18, 2005.
  1. VTEC_CBR
    VTEC_CBR Senior Member
    Virginia Beach
    so my roommate is a mechanical engineer major. and about a week ago i showed him the video of the ariel atom, and that inspired him to want to build something similar for his senior project in 2 years. so anyway, we had decided to use a b16a or b18c1. but in thinking about it i came upon some problems. 1) (i don't know if it's a real problem, but it sounds like it might be) the fact that the axels on fwd cars are cv axels. this being a rwd set up we'd be using, i thought that those axels might come into play. 2) the shift linkage would go towards the back, at first i thought, well, we could mount the motor in backwards, but then it hit me that no. if we did that, we'd be able to go way fast in reverse, but have the reverse gear to launch us forward. so if it was in there in the correct position, we'd have to fabricate custom shift linkage. at this point it looked like the project came to a standstill. but then it hit me, correct me if i'm wrong, but isn't the mr2 a rear motor rwd? i thought, we could use a 3sgte which looking on totaljdm.com or something like that, don't remember, anyway supposedly has 245hp and 225 lb/ft torque. so what do you think about my new idea? any advice? suggestions? thanks
  2. 92civicb18b1
    92civicb18b1 The Trisexual
    that could work also, maybe even better.
    Cant you just loop the linkage around, put like a 180* bend since you're going to have custom linkage anyway?
  3. VTEC_CBR
    Virginia Beach
  4. VTEC_CBR
    Virginia Beach
    yeah, the only thing is that we want to do it as simply but as well done as possible. we don't want to HAVE to make custom linkage if we can avoid it y'know
  5. Dustin_m
    Dustin_m Active Member
    San Diego, CA
    Do the SC'd camry V6 like some guy did in his MR2. Cant remember what mag but it was in SCC or Sport Compact or something a couple months ago.
    just throwin that out ther, i know you probably cant fit that in cause its bigger
    edit: tranny was a solara manual tranny
  6. 92civicb18b1
    if it could work there shouldn't be too much work involved in it, a few cuts a few welds and *taa daa*
  7. VTEC_CBR
    Virginia Beach
    what about the axels? is that a factor? or should i find custom non cv axels for it?
  8. hcivic.com
    hcivic.com Senior Member
    Calgary Alberta canada
    ya cv joints won't cause any problems at all they are used in the rear of a lot of vehicles the only concern is the power level they can stand
  9. reckedracing
    reckedracing TTIWWOP VIP
    NY
    axles are ok, but getting the power from the axles to the wheels will be a whole diffrent story...
    spindles in the rear perhaps?
    lol
    you may want to look into an H22 instead of the b series
    H22 has a cable shifter that would be easier to use with a rear mount motor...
    search online for H22 powered mini, some guy did that swap and has lots of detailed information on it
    this sounds like a bit much for a senior project, gonna need lots of money too
  10. Guy
    Guy Senior Member
    Yuba County
    There is also a RWD del sol with an H22 you can look into. I seem to remember a few posts about it at H-T.
  11. civicious
    civicious FüK-VTEC VIP
    Houston, TX
