anyone who rides or used to ride on here?
can you recommend a chain/sprocket combo?
my friend recommened RK and renthal...
Quoted post[/post]]
Only issue with Renthal is they're Aluminum. That's fine for the front, but the rear can take a beating. I would stick with a steel rear.
In these chains an X-shaped rubber seal is fitted between the inner and outer links, the extra two points against the links retain internal grease and stop dirt entering. With characteristic lower friction levels and increased running performance over O-ring chains, X-ring chains are recommended for higher powered and touring bikes.
