Auto Motor
Discussion in 'HYBRID -> EG-EK / DC' started by hybridhatchls, Mar 3, 2003.
  1. hybridhatchls
    hybridhatchls Junior Member
    I dont think it should matter but just to get some reassurance I had posted b 4 and asked what else was needed for a b18b1 swap. I found out today that the motor was once automatic. Will a pilot bearing still fit into the it?? or what is needed???
  2. D16z6CrxDx
    D16z6CrxDx Senior Member
    if ur going 5 speed u just need a 5speed flywheel othern then that ur good..to be honest its better that its an auto because u can put really hard miles on and auto cuz the rev limiter is so low..so its a good thing but as for JDM b16 auto's..its a bad thing because the motor has like 15 less HP then the regular 5 spd...
  3. hybridhatchls
    Ahh yes the piolt bearing just presses into the flywheel thanks alot bro :)
  4. solblu
    solblu Senior Member
    Ricer
    And you need Manual Tranny bolts for the flywheel cause they are longer than the auto ones.
  5. beau_safken
    beau_safken Senior Member
    Seattle, Washington
    Just go buy a new pilot bearing for like 15 bucks. Also you have to change a jumper in your automatic ECU to make it a manual. Go on hondata.com and download the instruction manual to figure out how to do it.
  6. hybridhatchls
    i dont have an automatic ECU im getting a manual one
