tomuchtortillas
So basically I'm starting out this project by switching trannys .I'm getten a 5 speed from a d15 I have the clutch and pressure plate as well as the trow out bearing tommarow I'm picking up the rest from this part out . I'm getting the flywheel pedel assembly ,clutch cylinder,all the linkages, short shifter ,all the metal tubings any harnesses ,mounts ,do I need the starter ? What else should I take for the swap I've read around they say this swap isn't that hard so ima try it myself .do I need the ec to ?
