auto to manual conversion
Discussion in 'HYBRID -> ED-EF / DA' started by gount175, Apr 1, 2004.
Thread Status:
Not open for further replies.
  1. gount175
    gount175 Member
    New York
    what parts do i need to do an auto to manual conversion on a 93 civic hatchback
  2. brian11to1
    brian11to1 Senior Member
    This needs to be moved. You r car isnt even a EF OR DA. You have an EG 92-95 Civic. So post in the correct forum
    Things you'll need:
    Clutch
    Clutch pedals assembly
    clutch reservoir
    master cylinder
    clutch hard lines from donor car
    shift linkages
    shifter bushing
    shift knob and boot
    5 speed ecu
    tranmission
    manny tranny mount...
  3. reckedracing
    reckedracing TTIWWOP VIP
    NY
    i believe a 93 is hydro, if not then sue me...
    but if it is hydro then you need clutch pedal assembly, hydro lines, manual trans, flywheel, clutch and pressure plate...
    and possibly axles, not sure on the auto intermediate shaft
    hydro lines includes the slave cylinder, and the clutch assembly includes the master cylinder by the fire wall
    you will need to unplug your auto computer, but you have to splice the wires that keep you from starting the car unless its in neutral or park, and you should be set...
    EDIT: shifter setup and manual tranny mount :worthy: ^^^^^
  4. brian11to1
    yes recekd you are correct, but ill be sueing you anyhow. 92+ HONDA = hydro, 94+ ACURA = hydro. I forgot toe mention flywheel, clutch kit
  5. reckedracing
    NY
    lol, between our two replies he'll know everything he needs
    lol
  6. brian11to1
  7. GSRCRXsi
    MD
    This topic has been closed :locked2:
    Why? It is in the wrong place. Please post your topic in the right forums. Hybrid is not for suspension or interior posts. EG is not for EF questions, and so forth.
    If you have any questions, please PM the moderator who closed this topic.
    -The moderating Team
Thread Status:
