auto to manual conversion
Discussion in 'General Tech and Maintenance' started by cheese9988, May 18, 2004.
Thread Status:
Not open for further replies.
  1. cheese9988
    cheese9988 Senior Member VIP
    Lowell, MA
    Someone awhile back did a write up on a auto to manual conversion and said something about a cable that went I think over by the passenger side for the ignition. Well I got my key stuck in the ignition and am looking for this stupid cable? Anybody know where it is. Its a `91 crx.
  2. phunky.buddha
    Dallas / Fort Worth, TX
    I don't know what you removed when you did your conversion, but make sure that the car "thinks" that the old auto shifter is in park. My gear selector module is still in the car, so I just locked it to P with a custom bracket that I made in about 5 minutes. If you cut yours, get the right resistance (or whatever signal it's throwing) from the wires that correspond to park, then make sure that the car "sees" that signal all the time.
  3. cheese9988
    Lowell, MA
    hmm, sometimes it wants to come out sometimes it dont....there was a wire harness by the shifter I havn't hookup up yet because I didn't wire the backup lights yet. I thought it was some cable or something.
  4. phunky.buddha
    It should be a signal sent to the key interlock mechanism. You just have to trick the interlock into thinking that you're always in park.
  5. asmallsol
    asmallsol Super Moderator
    Houghton/Livonia Michigan
    When I did this swap for a freind, I wired up the park safety switch to itself, so that way it always made contact. The park safety switch is just a switch that when in park, it makes contact. The car no longer has the gear selector module in the car and works fine.
  6. phunky.buddha
  7. deth101
    deth101 Senior Member
    usa
    I havnt started my car yet but have ben told by a few people that the little blue box under the dash is the interlock device and removing it will fix this prob,is that correct also?
  8. brian11to1
    brian11to1 Senior Member
    Teh little box thing next to where the shifter used to be... it slideds back and forth inn p - n etc... push the little slider all the way up into P then super glue their. this makes the car think its in park and the key will come out.
  9. deth101
    usa
    I mean the blue box under the dash.
  10. cheese9988
    Lowell, MA
    hmm slider thing next to the old shifter....I don't see that there maybe I removed it? :blink: I think I will try the wiring that asmallsol did and see how that works.
  11. deth101
    usa
    post what wires you connect if its not too much trouble,I would love to know,thanks.
  12. cheese9988
    Lowell, MA
    Yep, that was a super easy fix, I looked at the old automatic shifter and figured out which wires you need. Basically on the side of the old automatic shifter there is a white slide switch that is bolted on, take it off. Take off the zip-tie and remove the tape around the wires. There are three black wires in there, 2 striped, 1 not. Cut black wire (not striped) as close to the solder joint as possible. Cut the green/white wire (farthest green wire away from harness) as close to the solder joint as possible. Splice, and SOLDER the two wires you just cut together, shrink tube or tape it. Plug the nine pin wire harness in and leave it under the molding, nobody is going to look under there anyway. Your done, you can now remove your key!
  13. deth101
    usa
    thank you for updating. :worthy:
  14. lonelydriver
    lonelydriver Member
    anyone have the link to that write-up?
  15. brian11to1
  16. nselec9552
    nselec9552 New Member
    When i did mine auto to manual conversion on my del sol, i took the wire coming off the igntion switch to the harness by where the auto handle used to be and spliced them together. They were two black wires a black/red goin to the starter solenoid, and a black white striped wire going to the ignition switch, when i spliced them the car cranked fine.
  17. BrutalB83
    Rochester Hills, MI
    Thanks for the info buddy, but try to be cognizant of the dates on these threads. This question was posted five years ago and it hasn't been touched since just now when you responded to it.
    If anybody else has anything to add here, let me know, otherwise, this thread = :locked:
Thread Status:
