Auto To Manual Swap
Discussion in 'Engine Building' started by civicdude98, Mar 5, 2003.
  1. civicdude98
    civicdude98 Junior Member
    i am thinkin about swaping a D16Y8 motor with a manual tranny into a D16Y7 auto car what all do I need to have to accomplish this?
  2. jeffsciv23
    jeffsciv23 Senior Member
    Wa
    you will need tranny, flywheel, clutch, slave cylinder, master cylinder, pedals, new ecu (i think you might be able to use you old one if you cut some wires), and the fluid lines and misc bolts. anybody help me out if i missed anything.
  3. aznhottiekj
    aznhottiekj Senior Member
    what is a slave cylinder and master cylinder??
  4. dohcvtec_accord
    dohcvtec_accord WRX Sellout
    The left lane
    The clutch master cylinder is where the clutch fluid is contained (in a hydraulic clutch setup) and distributed from, and the slave cylinder is at the end of the high-pressure high and is what actuates the throwout bearing inside the tranny. They don't exist in a cable clutch setup.
    Someone please elaborate or correct me if I'm wrong.
  5. jeffsciv23
    Wa
    nope, that sounds about right to me.
