Note:my engine is D15B I'm going to swap my auto tranny with manual tranny : Is this all parts needs for swap: manual tranny shift linkage pedal assembly manual ecu manual center console I've few Q's : will shift linkage and pedal assembly from EF & EG and 93-96 CRX for my EK ? My car isn't vtec do I need manual ecu ? What's the type of ecu's for manual civic ? L3,S20 and S40 is options which better and why?
I beleive that your tranny is with cable, I would do a little more research, but if I am not wrong you are missing the Master cylinder and master slave...Manual Mounts and a short shifter or the oem, and shift knob.. with the pedals u can use any clutch pedal from 92 to 00 and the gas and brake I would say from 92 to 95 but if what you found is the set from a 96 to 00 you can still used u just need to change the brake plug from the one on a junk yard and would fit...
