auto tranny won't shift after B18 swap
Discussion in 'Integra' started by kaspann, Sep 20, 2009.
  1. kaspann
    kaspann New Member
    Just swapped in a B18 into 91 integra with auto. Original engine blew. New engine works great but auto transmission now will not shift out of 1st. I can manually go to 2nd (sometimes).
    I thought maybe the transmission took damage so we just swapped that out today and SAME THING. All the posting I see talk about something with the transmission itself, but that is impossible at this point. I am 100% sure this transmission is perfect.
    I could really use some assistance on this one.
    1 person likes this.
  2. dc4dude
    dc4dude Member
    chicago, il
    your shift cable is probably kinked or damaged. take off the center console and look for anything unusual. take a look in the underside of the car, follow the shifter cable routing and look for damage or cracks to the shifter cable itself.
  3. eman13
    eman13 New Member
    SOCAL
    check your passing gear cable it might be to lose or to tight , u could adjust it , its next to the throttle cable
  4. 90_EF_Hatch
    90_EF_Hatch Señor Member
    Dallas Texas
    How do you remove the shift cable from the tranny on an automatic?! im stuck
