rudeludenotmeanthough
There are two wires on my alarm green, and blue, for the door lock outputs. While locking the green wire is (-), and the blue is (+). While unlocking the green is (+) and the blue is (-). my solenoids both have a blue and green wire.
now heres the prob.
the outputs from the alarm ar LOW voltage outputs, and BARELY put out 1 volt (both the blue and green wire). I have come up with a relay setup that uses four relays to operate the solinoids using 12 volts. I was just curious, is there another way to make the soilenoids operate without using relays? but seeing as how they put out less than a volt, i dont think its possible. If i were to do that, i would probably have to use capacitors, and i dont feel like designing the system, etc.
so relays, is what I have come up with so far.
this works.. you guys have anyother ideas? How do the "pro's" do it at the shop? or do they use relays as well?
now heres the prob.
