automatic to manual
SIRH22
Member
How much would it cost to do an automatic to manual conversion on a 94 accord EX?
Here are the parts that you need, so you can add them up by yourself....
Transmission
Linkage and shifter
ECU
Axles
New front trans mount
Custom top transmount. (Placeracing, HAsport, ect)
Manual Pedal assembly (yes you need the manaul brake pedal and gas pedal)
Clutch master cylinder
Clutch line
Clutch and flywheel if the manual trans did not come with one (good time just to get new ones)
If you dont get the bolts for the flywheel and pressure plate, then you need them (a bunch of money, like $5 a bolt)
Normal swap fluids.
